Thank you for the welcome!!!
Oh i see now. That explains alot, so my motor was swapped out with a 72 model 307. Well i guess 350 it is. Maybe ill just sell this motor. it was just rebuilt. Does anyone know how much a 350 turbo trans can hold (guess its stock, no shift kit as far as i can tell)? This is my first project car dont know much about this stuff, trying to learn as I go. |
Check this other post on the TH350, last reply. http://www.chevelleforum.net/showthread.php?t=773 |
Welcome to the site....
It will be tough to get any significant amount of $ for the 307. Maybe a corner of the garage is a good place for it, to keep as a spare. Does the VIN stamp on the top front pass side of the block match the VIN of your '72? Right in front of where the head mates to the block deck there is a pad on the deck. It has some numbers stamped in it, and they match the vehicle the engine was originally bolted to. You either have an impoSSter, or an engine swap from something bigger to the 307. There is really no way of verifying if a '72 is an SS without original dealer/manufacturer documentation...unless the car was a W code (VIN engine designation) 454. Do you have: boxed lower control arms rear sway bar SS dash SS steering wheel |
Thread Tools | |
Display Modes | |
