Old 01-07-2010, 05:35 AM
Chicken Coupe Chicken Coupe is offline
Have you looked into these?
http://www.stickypod.com/
Old 02-21-2010, 11:57 AM
John D's Avatar
John D John D is offline
What about a short stick, with a ball/swivel mounted on a plate trapped under the dome light? (granted this'd only work if your camera has an inverted/top mounting lug..)
Use these all the time for CCTV - http://www.global-download.schneider...$File/c217.pdf
"Some days you're the pigeon, most days you're the Statue!"
'65 El Camino - 383, TH350, SC&C susp, 4wh discs
'96 Roadmaster "Buford"
Old 02-22-2010, 12:52 AM
I was going to wait until I posted some videos with my contraption, but since this thread surfaced, what the hey...
My camcorder happens to (and maybe this is a standard size) have 1/4"-20 female threads in the tripod mount boss. I used that hole, some bolt/nuts/flats/locks, a steel shelf reinforcer, and 2 cable ties to rig up a sweet little camera support.
The shelf reinforcer is something I had laying around. Probably 12 ga. sheet metal bent into a "C" , with each side of the C being about an inch. The length is 18"...kind of like a piece of 3 sided square tubing.
One end has a 1/4"-20 stud with a flat/lock/nut for the camera. I screw the camera on a few turns and snug it in place by tightening the hardware against it when it is pointing the right direction. The bolt is also fastened onto the "C", on the bottom horizontal side. Once I got it mounted, I bent the "C" out until it was pointing out of the windshield right, from its vantage point right between the seats, at shoulder level.
The other end of the "C" gets zip-tied to the 2 headrest posts on the passenger front seat.
It works perfect. I have tested it a bit, and it holds steady. I need to get out to somewhere desolate to make some fun vids, but it is all set for when I get the chance.
It works well.
Old 02-22-2010, 08:42 AM
Pictures?
Old 02-22-2010, 04:30 PM
Sure D.
This is the 18" length of C channel.
here's end of the "C" piece.
Here it is with the camera mounted.
Here's some in the car...
It was not an exacting science, as you can see from my handiwork bending the metal.
Also, I just rested it in place against the headrest posts instead of zip tying it in place for the pics. I'm sure you get the idea though.
Old 02-22-2010, 05:19 PM
John D's Avatar
1/4-20 IS the industry standard (commercial or consumer) for camera mounts... everything else is metric... it must drive them nuts!
Old 07-02-2010, 11:48 AM
Well, I never did get around to making a mount, but I just picked up one of these yesterday...
http://www.goprocamera.com/
Has suction cup mount, and came with stick-on permanent mounts also (Helmet cam! ) I'll be getting a lot of cool videos next time out.
Old 09-17-2010, 06:06 PM
fst64_v8power fst64_v8power is offline
Never had but good luck!
Old 09-17-2010, 08:15 PM
BigRat632 BigRat632 is offline
try GOPRO website
