Old 09-17-2020, 11:04 PM
67-ls1 67-ls1 is offline
Air intake plenum behind drivers headlight.
Pypes 2.5” system with 50 series Flowmasters.
ID:	4539   Click image for larger version
ID:	4540   Click image for larger version
ID:	4541   Click image for larger version
Old 09-17-2020, 11:12 PM
I’m playing with a front spoiler design. This is still a work in progress. I put it in a jig and heated the crap out of it. It helped some but I probably needed to be more aggressive with the bends and heat.
ID:	4543   Click image for larger version
ID:	4544   Click image for larger version
ID:	4545   Click image for larger version
ID:	4546   Click image for larger version
Old 09-17-2020, 11:20 PM
So after driving a few thousand miles and lowering the car a little more, the driveshaft rubbed the floor when carrying a passenger. I had already enlarged the trans tunnel and the forward part of the driveshaft tunnel but didn’t go back far enough.
So I’ve gutted the interior again and cut the floor out from the trans output flange all the way back to where it kicks up to the trunk.
ID:	4548   Click image for larger version
ID:	4549   Click image for larger version
ID:	4550   Click image for larger version
Old 09-17-2020, 11:27 PM
Cutout all the way to the back and now the tunnel is going back in. The tunnel under the back seat is flat topped to make the seat frame mods easier. Hopefully.
The complete tunnel will give me just under 3” more inches of clearance.
I’m still working on this so I’ll post more pics as I progress.
I still need to build a mount for the shifter and a mount for the custom console. A stock console would never fit these new floor boards.
And I’ll need to strip the rear seat back down to a bare frame and modify the frame to clear the new larger tunnel.
ID:	4552   Click image for larger version
ID:	4553   Click image for larger version
ID:	4554   Click image for larger version
ID:	4555   Click image for larger version
Old 09-17-2020, 11:59 PM
I have literally 1000’s of additional pics if anyone wants anymore detailed photos of any aspect of my project. Or just questions...
Old 10-31-2020, 10:30 AM
I’ve carefully removed the upholstrey from the back seat to modify the seat frame to clear the new taller driveshaft tunnel. The frame is 3/16” rod so I fab’d up some pieces 2” taller and welded them in. The front edge where the upholstrey attaches with hog rings I fab’d up by shrinking, stretching and welding a piece of 18 gauge.
ID:	4565   Click image for larger version
ID:	4566   Click image for larger version
ID:	4567   Click image for larger version
ID:	4568   Click image for larger version
Old 12-03-2020, 06:51 PM
Added Dynamat to the new sections of tunnel and i’m starting the carpet process. The new tunnel is so tall I had to cut the carpet down the middle otherwise it wouldn’t reach the door sills. I’ll seam in another piece forward of and behind the console.
ID:	4633   Click image for larger version
ID:	4634   Click image for larger version
ID:	4635   Click image for larger version
ID:	4636   Click image for larger version
Old 12-12-2020, 03:42 PM
Buttoned up the carpet and custom console. Ready for a front end alignment and back on the road.
ID:	4641   Click image for larger version
Old 12-12-2020, 07:22 PM
Looking good there.
Old 12-21-2020, 07:43 PM
Finished up my front air dam.
I made plates to mount it behind the bumper. I thought it would look better back a bit from the bumpers edge.
It also peaks in the center and fades back to the sides and wheel wells.
I wasn’t sure if I wanted it black or body color so I sprayed it white with peeling paint. More like a lower valance. I can peel it off it I didn’t like it.
What do you guys think, black or body color?
ID:	4676   Click image for larger version
ID:	4677   Click image for larger version
ID:	4678   Click image for larger version
ID:	4679   Click image for larger version
